DCB
Digital Communications Bus
Prior to MIDI, this was implemented on the Roland Jupiter-8 (some units) and Roland Juno-60
From Hyperreal:
From tmoravan@netcom.comTue May 30 10:16:25 1995
Date: Tue, 30 May 1995 03:57:58 -0700 (PDT)
To: rbcIII robot@crl.com
Cc: analog analogue@hyperreal.com
Subject: Re: DCB cable pinouts
Some folks have asked about the Roland DCB pinouts. Here is what I have from the Jupiter-8 service manual:
DCB Pin Configurations
| 07 06 05 04 03 02 01 |
| 14 13 12 11 10 09 08 |
(view from rear panel)
1 - Busy (receive)
2 - Data (receive)
3 - Clock (receive)
4 - Ground
5 - Busy (transmit)
6 - Data (transmit)
7 - Clock (transmit)
8 - unregistered
9 - VCA lower
10 - VCA upper
11 - VCF lower
12 - VCF upper
13 - VCO-2
14 - VCO-1
There were 2 different shapes of DCB cable and 2 different types. Early shape was a flat cable used to connect early OP-8 converters to the Jupiter-8's with the OC-8 interface installed. This was part # H146
Later cables used the D-sub shell.
Cable # H172 is a uni-directional cable with the signal flow indicated by the arrow on the connector. Cable # H172 is wired up like this:
| Receiver | Sender |
| 1 | 5 |
| 2 | 6 |
| 3 | 7 |
| 4 | 4 |
Cable # H165 is bi-directional. The manual warns: “DCB Cable H165 is a bi-directional cable in which sent from the TX-terminal on a unit returns to the RX-terminal on the unit, causing regeneration.” So, if you get regenerated don't say you weren't warned.
Receiver Sender
1 5 2 6 3 7 4 4 5 1 6 2 7 3 8 8 9 9 10 10 11 11 12 12 13 13 14 14
Hope this helps.
_______________________________________________________________________________
Tom Moravansky tmoravan@netcom.com
quiet electronics \\
From squishy@bga.comTue Jun 13 12:10:01 1995
Date: Tue, 13 Jun 1995 14:04:59 -0500
To: analogue@hyperreal.com
Subject: Re: MD-8/DCB (pinout info)
I've done the unthinkable (for me), i've opened my DCB cable to finally find out the truth on the pinout. I tried building one awhile back without success, I now know why.
If you want to build your own, you'll need a piece of 15 conductor cable, 14 wires and 1 ground. The ground is what I screwed up. You'll also need two Centronics 14 conductor connections.
The pinout…
The ground is connected to the front housing snap-in piece. Positions 8-14 are wired 1 to 1, that's the bottom row.
Below you'll see the pinout for the top row, positions 1-7.
| p | p |
| o | o |
| s | s |
| i | i |
| t | t |
| i | i |
| o | o |
| n | n |
| 1 wire 1 | 1 wire 5 |
| 2 wire 2 | 2 wire 6 |
| 3 wire 3 | 3 wire 7 |
| 4 wire 4 | 4 wire 4 |
| 5 wire 5 | 5 wire 1 |
| 6 wire 6 | 6 wire 2 |
| 7 wire 7 | 7 wire 3 |
Hope this helps.
Vince.
Squishy Records
From tmoravan@netcom.comWed Jun 14 11:49:55 1995
Date: Wed, 14 Jun 1995 04:34:38 -0700 (PDT)
To: MARSHALLR@opsusa.sms.siemens.com
Subject: Re: Jupiter8: DCB vs DCIB?
Well, since there are a couple of open threads regarding Jupiter8/MD8
questions, I might as well jump in with my own…..
I have a Jupiter8 that has some sort of factory interface, but I don't think
it is DCB, since it doesn't have the typical 14 pin 'D' connector up near the
“Roland” logo. Rather it has a 20 pin IDC ribbon connector w/ a slide switch
down low, near the serial plate. Could this be the earlier version of DCB,
known as DCIB, and can I use the MD8 or PRO4 DCB interface with it?
Any Roland/Jupiter experts have a clue?
Well - I can't find my original DCB post, so I hope someone archived it at the analogue site. Basically, it sounds like you have the Jupiter-8 version with the OC-8 DCB retrofit. The earliest versions used the flat cable scheme. The OP-8 (not OP-8M) cv→DCB converter has both types of DCB connections on it. After some time, Jupiter-8's were made with the DCB stuff built in and they switched to the 'classic' d-sub connector.
My post had the pinouts so you could make your own cables. There were 2 different kinds of cables - one that was only half-wired and provided one-way communication and the other was fully wired for 2-way traffic.
___
From fEEd@maroon.tc.umn.eduWed Jun 14 13:13:59 1995
Date: Wed, 14 Jun 95 14:58:32 CST
Subject: Re: More DCB/MSQ-700?
On Wed, 14 Jun 1995 08:42:46 -0700 (PDT), Michael Winton <mwinton@uclink.berkeley.edu > wrote:
I know the 700 can send MIDI or DCB out. I know from reading in the
archives that it cannot “convert” MIDI to DCB. Can I record a DCB
sequence from my Juno 60 into the MSQ-700 and then play it back, WITH the
700 “synced” to the MIDI clock?
Sorry, but no. The bastards.
Rob
fEEd/>tEMpESt<\http://www.umn.edu/nlhome/m211/feed/<\fEEd@maroon.tc.umn.edu/>
"FILTER MAINTENANCE- After every 100 hours of operation apply a sine wave to the output of the FILTER to back flush the trapped overtones to unclog your filter." - EML 101 Manual
