this is one essential part for my triggermatrix5
i need a core pcb which is aviable in Europe, and uses the stm32F407VGT6 chip, which has 1MB ram…
i think there is a error - PB2 is not connected to the CORE MODULE
parts off it is pick and place the other part is handsolder
the LCSC Parts are done with the Pick and place - so no need to order…
Comment | Designator | LCSC | Lot |
SN74HC541 | IC1 | C116811 | 1 |
1K | Ra1,Rb1,Rc1,R5,R6,R7,R8,R24 | C11702 | 8 |
J10B | GPIO1 | C124391 | 1 |
AIN | J5A/B1 | C124391 | 1 |
DIN/DOUT | J8/1 | C124391 | 1 |
MCP3208 | IC2,IC3 | C16939 | 2 |
10 | R17 | C17902 | 1 |
6N138-SMD | O1,O2,O3,O4 | C188666 | 4 |
Pin-Header-2×4-SMD | AIN0,AIN1 | C192300 | 2 |
J4A+B | IIC1 | C192300 | 1 |
J15A | JA15 | C192300 | 1 |
J10B | JB10 | C192300 | 1 |
- | Midi1 | C192300 | 1 |
LED | LED1 | C2286 | 1 |
220 | R1-4,R13-21 | C25091 | 12 |
2K2 | R22,R23,R25,R26 | C25879 | 4 |
4K7 | R9,R10,R11,R12 | C25900 | 4 |
100n | C4,C6,C7,C8,C10,C12 | C307331 | 6 |
10uF | C1-5,C9,C11,C13-15 | C440198 | 9 |
uSD-Molex | SD1 | C585350 | 1 |
1N4148W | D1,D2,D3,D4,D6 | C81598 | 5 |
The Mouser parts that have to be soldered by hand - you have to order them on your own…:
Comment | Designator | MouserNumber | Lot |
PW2 | TSR_2-2450 | 495-TSR2-2450 | 1 |
USB1 | USB-B-Socket | 538-67068-8000 | 1 |
D5 | 1N5818 | 583-1N5818-T | 1 |
Midi1 | - | 649-1012938390801ALF | 1 |
Midi-IN1-2, Midi-OUT1-2 | Midi-KCDX-5S-S2 | 806-KCDX-5S-S2 | 4 |
DISC1 | STM32F4DISCOVERY | 511-STM32F407G-DISC1 | 1 |
PW1 | PJ-079BH | 490-PJ-079BH | 1 |
SW1-3 | Power | 611-1101M2S4AV2BE2 | 3 |
USB3 | USB_A-Molex | 538-89485-8000 | 1 |
copy following list into this mouser.com-Link
495-TSR2-2450|1
538-67068-8000|1
583-1N5818-T|1
649-1012938390801ALF|1
806-KCDX-5S-S2|4
511-STM32F407G-DISC1|1
490-PJ-079BH|1
611-1101M2S4AV2BE2|3
538-89485-8000|1
Order from Reichelt:
2x 2x25Pin Female 2,54mm Heades
1x 1x20Pin Male 2,54mm Header
1x 2x10Pin Male 2,54mm Header
5x 2x5Pin FeMale 2,54mm Header
4x 2x4Pin Female 2,54mm Header
1. If the Discoveryboard is a virgin-one then upload the bootloader via stm-utility
2. Upload the Bootloader
3. Disconnect and Reconnect the USB-Cable to your PC, then type “help” into the MIOS-Terminal, this should print out the actual Board-Configuration, if this happens then:
4. Type following commands:
* set lcd_type 0x84
* set lcd_num_x 26
* set lcd_num_y 1
* set lcd_width 128
* set lcd_height 64
* store
at least this has to be done when using this core for Triggermatrix5
It works! next variant will be, without Discoveryboard and the STM32F407vgt6 directly soldered to the board…
